seattlehiker
Mar 17, 2021Aspirant
EX3700 setup problem. "no internet" response using Android
I've been trying to set up the EX3700 wifi extender for several days. WPS doesn't work so I did a factory reset and got the Netgear EXT readout in my Android Wifi manager and then used a its Chrome b...
seattlehiker
Just to be clear. I have wifi using my router directly. My Android phone can connect to my router wifi. When I try to use my phone to connect to the wifi extender address that's when it says "no internet".
DexterJB
Apr 13, 2021NETGEAR Moderator
- seattlehikerApr 13, 2021Aspirant
I got it to work but I'm not quite sure how. I tried it with an older phone and I got it to work. Then when I tried it with my new phone that then worked?
Anyway, it works now. It's a bit sporatic in that sometimes it has 3 green lights, sometimes, they are yellow or one might be red. Later, without me doing anything, they are green again.- DexterJBApr 13, 2021NETGEAR Moderator
Thanks for the update. Let us know if the issue ill persist.
Dexter
NETGEAR Team
