Dmbram's avatar
Dmbram
Initiate
Jun 27, 2021
EX3700 signal strength spec
I have an EX3700 dual band extender that is set up to extend both 2.4GHz and 5GHz signals from my Telstra Gen2 DJA0321 Smart Modem. The extender is about 15m from the modem and almost line of sight (...
  • plemans's avatar
    Jun 27, 2021
    dbm isn't a good way of checking signal because of underlying radio noise. Its a SNR (signal to noise) issue.
    Actual speedtesting and stability are more important.
    a couple things.
    1. your extender should be midpoint between where you need signal and where the router is. Reason why is the extender needs a decent signal to pick up and rebroadcast. If its where the laptop is, the laptop might as well as just direct connect to the router because it'll suffer from less throughput drop going through the extender
    2. if you're living in apartments, condo's, homes living close together, then 2.4ghz tends to be much less stable because it broadcasts futher and suffers from more interference by the very nature of its spectrum. If you're device has 5ghz, it should be on it in close living situations.
