sam340190
Nov 21, 2021Aspirant
EX3700 to Inseego 5g hotspot connection issues
Hi there, I am having issues connecting a ex3700 wifi extender to an Inseego 5ghotspot from tmobil. The process I have tried is as follows. 1. reset extender. 2. find the extender network, netgea...
Nov 21, 2021Guru - Experienced User
I couldn't find much info on that hotspot because its a pretty new 5g hotspot.
If the extender is working off the phone's hotspot/other devices, it'd make me wonder if tmobile has something in it locked down to prevent repeating. Or if its a setting on the M2000.
Are you using wpa3 on the M2000? Try disabling wpa3
Are yo using any special characters in the ssid/password for the hotspot? Try removing them.
