daddyis1
Apr 07, 2020Aspirant
Ex3700 Wifi Extender
Hello Community, Device light on my extender is intermittent (every 5 - 10 minutes) but the router, power and wps lights are all green. Can someone please suggest what I can do to fix
Apr 07, 2020Guru - Experienced User
The device light is on when devices are connected to it.
Is there an issue with it?
- daddyis1Apr 07, 2020AspirantYes, the light is intermittent, it goes in and out every 5 to 10 minutes
- plemansApr 08, 2020Guru - Experienced User
daddyis1 wrote:
Yes, the light is intermittent, it goes in and out every 5 to 10 minutesthe light going on/off isn't an issue. It means a device is connected and then not anymore.
What issue are you actually having?
- daddyis1Apr 08, 2020AspirantThe issue that I am actually having, is trying to find out why the devices are not staying connected continuously. Example my ring security doorbell is not staying connected to the extender which means I am not able to effectively use that device. Can you please tell me why you think the devices are not staying connected continuously.
Please respond
Thanks
