daddyis1
Apr 07, 2020Aspirant
Ex3700 Wifi Extender
Hello Community, Device light on my extender is intermittent (every 5 - 10 minutes) but the router, power and wps lights are all green. Can someone please suggest what I can do to fix
Apr 07, 2020Guru - Experienced User
The device light is on when devices are connected to it.
Is there an issue with it?
daddyis1
Yes, the light is intermittent, it goes in and out every 5 to 10 minutes
- plemansApr 08, 2020Guru - Experienced User
daddyis1 wrote:
Yes, the light is intermittent, it goes in and out every 5 to 10 minutesthe light going on/off isn't an issue. It means a device is connected and then not anymore.
What issue are you actually having?
- daddyis1Apr 08, 2020AspirantThe issue that I am actually having, is trying to find out why the devices are not staying connected continuously. Example my ring security doorbell is not staying connected to the extender which means I am not able to effectively use that device. Can you please tell me why you think the devices are not staying connected continuously.
Please respond
Thanks- plemansApr 08, 2020Guru - Experienced User
what router are you using?
firmware on your extender?
Most doorbells run of 2.4ghz signals. which are also more sensitive to interference. have you tried changing wifi channels on your primary router to account for this?
