Lobsternetty
Oct 03, 2020Tutor
Ex3700 WiFi range extender
Hi All: Im going to be staying in my RV in a friends yard and they said I could use their WIFi. I bought the EX3700 at a friends recommendation because they said the ones that plug in boost a be...
- Oct 03, 2020
yes it is. Its also one of the videos on the support site. video's and manual are found here:
Oct 03, 2020Guru - Experienced User
Yes you can. Just set it up using the installation assistant.
The 1 issue you might run into is that many campers have a metal exterior that does a very good job of blocking wifi. If you can plug it in with an extension cord and and put the extender in a windows within line of sight of the home, it might get you much better wireless signal.
- LobsternettyOct 03, 2020Tutor
Thanks so much for your suggestion! I’m not very tech savvy so I appreciate the help. How do I go about using the installation assistant? Is that covered in the owners manual?
- plemansOct 03, 2020Guru - Experienced User
- LobsternettyOct 03, 2020TutorThanks again for all your help! ☺️
