Lobsternetty
Oct 03, 2020Tutor
Ex3700 WiFi range extender
Hi All: Im going to be staying in my RV in a friends yard and they said I could use their WIFi. I bought the EX3700 at a friends recommendation because they said the ones that plug in boost a be...
- Oct 03, 2020
yes it is. Its also one of the videos on the support site. video's and manual are found here:
Oct 03, 2020Guru - Experienced User
Yes you can. Just set it up using the installation assistant.
The 1 issue you might run into is that many campers have a metal exterior that does a very good job of blocking wifi. If you can plug it in with an extension cord and and put the extender in a windows within line of sight of the home, it might get you much better wireless signal.
Lobsternetty
Oct 03, 2020Tutor
Thanks so much for your suggestion! I’m not very tech savvy so I appreciate the help. How do I go about using the installation assistant? Is that covered in the owners manual?
- plemansOct 03, 2020Guru - Experienced User
- LobsternettyOct 03, 2020TutorThanks again for all your help! ☺️
