Tom768
Apr 30, 2020Follower
EX3700 WPS LED Off
I setup the EX3700 two different ways - WPS and then later using the web browser (in order that could connect to my guest network). I have WPA/WPA2 enabled on my router. The EX3700 WPS LED will blin...
Bigzig
Jan 03, 2021Aspirant
I have had the same problem, I spent 30 minutes yesterday with tech support and the WPS light did not come on. I was told the product was defective and to get a replacement. I received my replacement today and went through the set up and the WPS light still is not on. The only time it will blink if you do a WPS set up. I have spent too much time on this issue.
