Fimoffat
Jan 08, 2020Aspirant
Ex3700
Hope someone can help.
I purchased this range Extender to be able to set up my new smart tv. It worked for a few hours! I am following all of the instructions to re-set it up. I keep getting server stopped working each time I try to complete the set up.
Does anyone have any ideas as to what I can do as this is driving me crackers
Does anyone have any ideas as to what I can do as this is driving me crackersYou're getting the server stopped working on your tv or on the extender?
What server stopped working?
What are the led's doing on the extender? color/blinking/solid/each light.
What firmware is on the extender?
What router are you connected to?
- FimoffatAspirantHi i am trying to set this up on my iPad. I can join the WiFi for the extender. I log onto mywiifiext.net. I go through the process of setting up and enter passwords where needed. I get to the end of the process and for some reason the WiFi goes back to my original WiFi rather than the extender. The message comes up either that I cannot connect to the internet or that the server has stopped working
Are you setting the ssid the same for the extender as the router?
do you have a device you can hardwire into the extender for setup?
