dcleal
Apr 09, 2022Tutor
EX3700/AC750 WIFI Extender setup failure
I have a brand new EX3700/AC750 WIFI Extender, which I can't set up as an extender. Each time I try to set it up, it gives me a list of Wifi networks, I select my 2.4GHz network and uncheck the 5...
dcleal
Apr 09, 2022Tutor
Update: actually, when configured as an access point, it does sometimes work - something like one reboot in two?
However, pushing it back to extender mode still fails every time.
- Dave
- plemansApr 09, 2022Guru - Experienced User
If its a new extender, you should have your 90 days of free support. Might be faster to go that route.
To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.- dclealApr 12, 2022Tutor
I'm sending it back.
It seems outrageously difficult to get any error information out of this, I've found a few mad articles on the internet about how to get this thing into a mode where you can telnet to it, but overall it seems that Netgear don't want to help people for whom it doesn't work. So I won't try and make them.
Thanks for the interest.
- Dave
P.S. This thread seems weird, it has stuff copied from another thread, at least not (knowingly) by me. Still, hopefully the gist is clear.
