ITFixt
Oct 11, 2021Aspirant
EX3800 Windows 10 connects OK, then randomly disconnects and says key is unvalid
Firmware updated today. UK model. Device is connected to router by Ethernet and is configured as an access point. Works perfectly with an HP printer and several phones. Windows 10 laptop conne...
Oct 11, 2021Guru - Experienced User
Do any other devices have issues?
Or just the one?
- ITFixtOct 12, 2021Aspirant
Just that one. I am aware that this sort of points the finger at it being a Windows 10 problem but (a) it was all working poerfectly OK for some months and (b) sometimes a Windows problem can relate to just one other device.
BTW, the laptop works OK with an old Belkin eouter configured as an access point! We'd rather use the Netgear extender, though, as it's a lot faster.- plemansOct 12, 2021Guru - Experienced User
what actual wireless card is having issues?
What driver version is it using?
What firmware is on the extender?
What router is the extender connected to?
Have you tried setting a reserved/static ip address for the laptop in your router?
