tdebacker
Sep 04, 2020Aspirant
EX3800/AC750 not sharing internet when restarted
Hello Everyone, thanks for reading ! My issue is the following: I followed the installation procedure and my extender replicated the wifi's of my router, I can connect to it but there is no internet...
Sep 05, 2020Guru - Experienced User
so you were able to set it up using the installation assistant if ran in the same room?
When you set it up using the cable, was it cabled to the router? If so, that sets it up in access point mode. If you meant you set it up with the cable to a computer, thats different.
How far did you move the extender from the router?
What are the interior walls in your home made of?
What are the led's on the extender showing when you moved it? (all of them, blinking/solid/color)
Firmware on the extender?
