OldHowie's avatar
OldHowie
EX500 WiFi Range Extender
Do all 4 lights need to be green to confirm my extender is working properly.  Thanks
  • plemans's avatar
    No. They don't. Here's there descriptions.
    LED Description
    • Solid green. The extender is powered on.
    • Solid amber. The extender is booting.
    • Off. The extender is powered off.
    Power
    This LED indicates the network connection between the extender and the
    router or access point.
    • Solid green. Best connection.
    • Solid amber. Good connection.
    • Solid red. Poor connection.
    • Off. No connection.
    Device LED Description
    This LED indicates the network connection between the extender and a
    computer or mobile device.
    WPS
    • Solid green. WiFi security is enabled (WPA or WPA2).
    • Blinking green. A WPS connection is being established.
    • Off. WiFi security is not enabled.
    • OldHowie's avatar
      OldHowie
      Thank you for your response but I am still a little confused.  The device light is the light that is not on.  Is my extender working (such as for a TV) and how can I tell if it is.  Thanks
      • plemans's avatar
        The device light comes on when something is connected to the extender.
        did you connect a device to it?
