DWBSr
Nov 29, 2023Initiate
EX5000 compatibility with Xfinity Arris XB3 Gateway
Is the Netgear Extender compatible with Arris XB3 Gateway? The extender that Netgear sells is expensive.
Nov 30, 2023Guru - Experienced User
Theoretically it should work fine. I say theoretically just because I've never used that gateway/extender but it should work.
Did you just buy that gateway? Because its a bit older/lower spec'd
- DWBSrNov 30, 2023Initiate
Thanks for responding.
I rent the gateway from Xfinity. Can’t remember how old. 3 to 4 years.
Have been thinking about buying one. I am hesitant as I don’t want Xfinity blaming any problems on me.
Open to informed suggestions.
- plemansNov 30, 2023Guru - Experienced User
If you've been renting for that long, you should be able to get it upgraded.
I'd contact them through chat/calling and ask about an upgrade to the XB7 or XB8 modem.
If you're renting, they tend to keep it a bit more current. Might just need that reaching out on your part - plemansNov 30, 2023Guru - Experienced User
