DWBSr
Nov 29, 2023Initiate
EX5000 compatibility with Xfinity Arris XB3 Gateway
Is the Netgear Extender compatible with Arris XB3 Gateway? The extender that Netgear sells is expensive.
DWBSr
Nov 30, 2023Initiate
Thanks for responding.
I rent the gateway from Xfinity. Can’t remember how old. 3 to 4 years.
Have been thinking about buying one. I am hesitant as I don’t want Xfinity blaming any problems on me.
Open to informed suggestions.
Nov 30, 2023Guru - Experienced User
If you've been renting for that long, you should be able to get it upgraded.
I'd contact them through chat/calling and ask about an upgrade to the XB7 or XB8 modem.
If you're renting, they tend to keep it a bit more current. Might just need that reaching out on your part
