jonfy
Oct 01, 2020Follower
ex6000 will not accept pass word
ex600 will not accept my vodafone router pass key
Oct 01, 2020Guru - Experienced User
Did you set it up using wps?
If so, factory reset the extender and re-install using the installation assistant and not wps.
WPS can get coded different and cause issues sometimes. Which is where there's also the install assistant.
