JessicaHoven
Jan 17, 2020Tutor
EX6100 Connection Issues following initial set-up
I recently purchased a second Netgear AC1200 EX6110 as the last one stopped working. The first unit worked great for the first 6 months and then started disconnecting from the router despite the gree...
- Jan 25, 2020
After many failed attempts at getting the WiFi extender to work, I ended up returning it to the store.
Swapped it over for a TP Link, which has worked perfect, so I think it is something glitchy with the AC6110 given two of them gave me this trouble. Thanks for your help with the troubleshooting :)
JessicaHoven
Jan 17, 2020Tutor
Excellent. I just found it (Firmware Version: V1.0.1.62). I checked for any updates online and after checking the system said all is up to date.
I have tried a factory reset of the extender before and am now reconnected to the internet via the extender. I will check again tomorrow and see if it is still connected or if it has dropped out again. I am unsure how to change wifi channels for the router or how to work out if the channel is congested. I live on a rural property, so I dont think it could be wifi interference, but might need you to explain that to me.
JessicaHoven
Jan 25, 2020Tutor
