bobmounger's avatar
bobmounger
EX6100 ethernet output connect to router?
I have shed on the end of my property, I had put an EX6100 & my garage to be able to access the internet in the shed & improve connectivity in my house.   This worked for several years, but now I a...
  • bobmounger's avatar
    bobmounger
    Feb 26, 2020
    Hi Dexter,
    Thanks for the reply. I finally got it to work. The EX6100 was working fine. I had to fix the configuration of the router.
    BUT lesson learned, The old router is a linksys wireless G & the outlet is switched. I mean that the power to the outlet is controlled by a light switch. I found that the linksys router apparently has no nonvolatile memory because even though I pulled the barrel plug in & out of the router several times with no ill effects, when I returned to the setup after having the power to the router turned off for a couple of hours, it had completely lost it's settings. A web search yielded numerous people describing the same thing. It sounds like Linksys uses a capacitor to retain settings instead of EEPROM!  Another good reason to buy Linksys
