shrmnmrk
Dec 07, 2022Tutor
EX6100 EXTENDER PASSWORD
I moved my office to my home and took my EX6100 with me. I did factory reset and connected to my home Nighthawk router, setting up the _EXT wifi network. Unfortunately I am unable to log in to the...
Dec 09, 2022Guru - Experienced User
Have you tried setting it up before? That isn't the default ssid.
Plus if you're connected to the extenders ssid and its giving you that notice, it usually means its connected to the router.
Log into the router and look at its attached device page. If the extender is connected, it should have an ip address on that page. Use that ip address to access it.
shrmnmrk
Dec 15, 2022Tutor
Yes. I had it working at my office, then I moved it into my home. I did factory twice.
I am a bit confused. Please give me specific instructions to "log into the router."
Thanks
Mark
- plemansDec 15, 2022Guru - Experienced User
Not sure what router you have but you can usually access them using a browser interface to change the routers settings.
From within that interference, there tends to be an attached devices page (or equivalent)
without knowing what router you connected it to, its tough to be specific on telling you how to access it but the routers user manual should go over how to access it using a web browser.
