shrmnmrk
Dec 07, 2022Tutor
EX6100 EXTENDER PASSWORD
I moved my office to my home and took my EX6100 with me. I did factory reset and connected to my home Nighthawk router, setting up the _EXT wifi network. Unfortunately I am unable to log in to the...
Dec 15, 2022Guru - Experienced User
Not sure what router you have but you can usually access them using a browser interface to change the routers settings.
From within that interference, there tends to be an attached devices page (or equivalent)
without knowing what router you connected it to, its tough to be specific on telling you how to access it but the routers user manual should go over how to access it using a web browser.
shrmnmrk
Dec 15, 2022Tutor
Thanks for your reply.
The router is:
NETGEAR Nighthawk Smart WiFi Router (R6700) - AC1750
Mark
- plemansDec 15, 2022Guru - Experienced User
try going to routerlogin . com or 192.168.1.1
log into the router there and then go to the attached devices page.
- shrmnmrkDec 15, 2022Tutor
Ok, now I see the attached devices.
Should I see the Extender there? I do not.
Thanks
Mark - plemansDec 16, 2022Guru - Experienced User
If its connected to the router, it should show up there. It might not say netgear extender under the description.
