spiritdream
Jul 05, 2022Follower
EX6100 not working with my Linksys router
The EX6100 worked before with the same router. I have tried to hook it up and it won't stay connected. I have reset the extender, still not hooking up. I go to my router maps, it says the extender...
Jul 05, 2022Guru - Experienced User
What router do you have?
What firmware is on the extender?
what method of setup are you using? WPS? Installation assistant?
