tevans84025
Feb 14, 2021Follower
EX6100 reset trouble
I have reset the extender to factory reset to connect to a new WiFi router. When I go into connect to Netgear.ext to setup the selection is not there - only the 2Gext and 5Gext are there and neither o...
Feb 14, 2021Guru - Experienced User
It might not of fully reset. push and hold reset for 7-15 seconds while its fully powered on.
If that doesn't work, you could always hardwire into the extender with a pc/laptop for setup.
