FBHO
Sep 18, 2020Follower
EX6100 WiFi Extender
I am trying to follow Netgear's directions for upgrading the Firmware on my EX6100 range extender. First, how do I check which Firmware version is running on it and second, if it requires a new Firm...
Sep 18, 2020Guru - Experienced User
The support site literal has a video showing using the upgrade assistant and using the manual method. I'd take a look at both
https://www.netgear.com/support/product/EX6100.aspx
simply click the > on the video's to see the other versions.
