Mrprofecy's avatar
Mrprofecy
Follower
Dec 06, 2020
Ex6100
Hi, I am having problem with my EX6100 WiFi Range Extender Installation Guide. I used this adapter before and it was a connected to my old wifi. Now that I try to install it again it seems like it connects to my new wifi but the names that appear in the adapter are my old wifi, I try to put the wifi of the new router but it does not work. I don’t understand how it still has the name of the old router because it was from6 years ago meaning that it was gone 6 years ago meaning its not in my house anymore meaning that I don’t understand how is connected. I try to reset it in the factory reset but it did not worked. So I was wondering if someone can help me with this problem, I would be really grateful. By the way my wifi router is WPS not WEP. Thank you!
  • plemans's avatar
    wps is a method of setup.
    WEP is a security method.
    What router are you connecting it to?
    What you factory reset it, did you push and hold reset for 7-15 seconds while the extender was powered on?
    then reinstall it using the guide. Don't use wps, use the installation assistant.
    https://www.netgear.com/support/product/EX6100.aspx
  • It seems they have shut off support for setting up this extender
    • plemans's avatar
      ol2 Its your only post in the forums and you gave no details.
      If you'd like help, please start your own thread and we're happy to help.
      • ol2's avatar
        ol2
        When I've tried to go in and reset the extender thru it no longer works and is no longer listed as a supported device on the set up webpage
