MikeVTA
Jun 18, 2020Aspirant
EX6100v Extender won't connect to router
New extender will not connect to router. After several attempts to set up (reset to factory settings each time), when I get to "Connect any WIFI enabled device..", the extender does not connect to m...
Jun 18, 2020Guru - Experienced User
What router are you connecting to?
what firmware is on th extender?
Did you setup via wps? if so, factory reset and redo the install using the installation wizard.
MikeVTA
Connecting to a Netgear model 3700 router. I have no idea about the firmware. It's whatever Netgear provides with this extender.
I did not set up via WPS, and yet the WPS LED lights up after partial setup. I've rebooted both the router and extender in addtion to resetting extender to factory settings.
- plemansJun 18, 2020Guru - Experienced User
Which 3700 model router? Whats the full model number?
And firmware is important for both of them. they both should have it on their status pages.
Go to netgear.com/support/ and type in their full model number. From there you can get the manual.
