mmh
Apr 25, 2022Follower
ex6100v2----connected to c7000v2 router, but the ext network doesn't show up
I have a Netgear C7000v2 modem/router and a Netgear EX6100v2 extender. I successfully connected the router to the extender (i.e., I can see the extender in the connected devices list when I login to...
Apr 25, 2022Guru - Experienced User
The EX6100v2 is a mesh extender. meaning if you set it up in its default mode, it uses the same ssid as the router and allows devices to roam between it and the router as needed.
You can disable that option if you don't need/want it
