yomommastank
Dec 22, 2020Aspirant
Ex6100v2 AP Performing Worse Than Extender Mode: Why?
I decided to switch my EX6100v2 as an AP instead of an extender. I have an AC1750 Wireless Dual Band Gigabit Router with 400 down. The EX6100v2 extender was consistently okay, but sometimes it will d...
Dec 23, 2020Guru - Experienced User
did you factory reset it and install it using access point mode?
Did you test the cat6 cable to ensure it wasn't the issue?
- yomommastankDec 23, 2020Aspirant
Yes, I did reset the settings. The cable seem fine when I connected it to my pc. I was getting around the 400 Mbps.
- plemansDec 23, 2020Guru - Experienced User
what firmware version are you on?
Waht router is it connected to?
When testing, are you making sure to test 5ghz seperate from 2.4ghz?
2.4ghz is much slower
- yomommastankDec 27, 2020Aspirant
The EX6100 is on V1.0.1.94
The router I am using the TP-Link C7 AC1750
What do you mean test the bands separately? Do you mean only enabling one band on?
