yomommastank
Dec 22, 2020Aspirant
Ex6100v2 AP Performing Worse Than Extender Mode: Why?
I decided to switch my EX6100v2 as an AP instead of an extender. I have an AC1750 Wireless Dual Band Gigabit Router with 400 down. The EX6100v2 extender was consistently okay, but sometimes it will d...
Dec 23, 2020Guru - Experienced User
what firmware version are you on?
Waht router is it connected to?
When testing, are you making sure to test 5ghz seperate from 2.4ghz?
2.4ghz is much slower
yomommastank
Dec 27, 2020Aspirant
The EX6100 is on V1.0.1.94
The router I am using the TP-Link C7 AC1750
What do you mean test the bands separately? Do you mean only enabling one band on?
- plemansDec 28, 2020Guru - Experienced User
yomommastank wrote:The EX6100 is on V1.0.1.94
You don't need to disable a band. Just make sure you test each band seperate. because 2.4ghz is so much slower, if you're using that for speedtesting and thinking its 5ghz, you'll think speeds will are atrocious.
- yomommastankDec 28, 2020Aspirant
Yes, I did test them both seperately. I know that 2.4 ghz will perform slower, but the AP was performing worse than the 2.4ghz and 5 ghz extender setting respectively
