FusedGlassDave
Jan 18, 2023Tutor
EX6100V2 Extender - Change router SSID
Our extender was set up with an incorrect name for the router WiFi SSID - it points to another access point in the house, instead of to the WiFi port set up in the router. I see no way to change ...
- Jan 21, 2023
if you get to the installation page, its not installed. That only pops up if its not connecting/installed properly.
Jan 18, 2023Guru - Experienced User
I would. And I'd use the installation assistant.
Factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
FusedGlassDave
Jan 20, 2023Tutor
Thanks for the tip!
I have now re-installed the extender multiple (5? 6?) times. Windows shows the connections to the extender SSIDs are "Connected, secured". So all seems to be going swimmingly well, except:
When I attempt to access the Internet through either of the extender SSIDs, I always get a long pause, and then an Edge error screen that shows a message along the lines of "[name of site} DNS address cannot be found." (Essentially the same thing happens when using Chrome.)
Any idea what's going on there?
- plemansJan 20, 2023Guru - Experienced User
What router is it connected to?
what firmware is on the extender?
- FusedGlassDaveJan 20, 2023Tutor
1. Router is ATT Pace 5268 AC
2. How can I access Extender's settings (current sw level, e.g.)? If I reset the extender, once I connect to its SSID, I can only seem to install it as a new device. If I connect to router SSID, then I see no way to get into extender to check its settings.
If its connected to the router, log into the router and check its attached devices page. If the extender is connected, it should be assigned an IP address. You can use that ip address to access it and check its settings/status and make changes.
