FusedGlassDave
Jan 18, 2023Tutor
EX6100V2 Extender - Change router SSID
 Our extender was set up with an incorrect name for the router WiFi SSID - it points to another access point in the house, instead of to the WiFi port set up in the router.     I see no way to change ...
- Jan 21, 2023if you get to the installation page, its not installed. That only pops up if its not connecting/installed properly.
FusedGlassDave
Jan 20, 2023Tutor
If I browse to the router using IP 192.168.1.254 while connecting via a "normal" SSID, the extender shows in the list of available SSIDs as "NETGEAR_EXT" but has no IP.
While connected via "NETGEAR_EXT" I can browse to "myWiFiExt" but the only result I can get is the Extender Installation page.
I'm stuck!
Jan 21, 2023Guru - Experienced User
- FusedGlassDaveJan 21, 2023TutorI think I've got it now - never satisfactorily completed the installation by bringing up http://miwifiext page, which actually completed it (best I can tell).
 [I found this last page in the installation process to be somewhat unclear. I waas simply checking the Continue box and moving on:]I am now able to connect via the extender SSIDs and access internet pages. Huzzah!
- plemansJan 21, 2023Guru - Experienced Userglad to hear you got it figured out!
