Kerrio
Aug 12, 2020Follower
EX6100v2 How to change so as to connect to a new modem
Our Internet provider (Optus in Australia) has provided us with a new modem to improve our internet connection but now our Extender is not working as it has the old password that no longer operates. ...
Aug 12, 2020Guru - Experienced User
Try factory resetting the extender and then following the new install guide.
to reset, push and hold reset for 7-15 seconds while its powered on.
You can find the install guide here: https://www.netgear.com/support/product/EX6100v2.aspx
I'd recommend using the installtion assistant when connecting to ISP supplied routers.
