ov10mech
Apr 17, 2021Star
EX6100v2 No Gigabit Ethernet
This unit advertsies is has a Fast 1GB ethernet physical port. I have tried to connect it to several 1GB clients and even forced 1gb/full through the NIC settings. I am using a new CAT5e cable tes...
- Apr 21, 2021
I got this Fixed. Although Cat 5e cabled are supposed to run at 1gb for some reason this adapter doesnt like them. The cables I have work fine on other switches. I ordered a Cat 6 cable and it went in at 1GB first time. Case closed. Now getting 250mbps vs 100mbps on the bandwith.
Apr 19, 2021Guru - Experienced User
it does have a gigabit ethernet connection. but its an AC750 extender.
so the best link speed (not the same as actual speed) that it'll connect to your router at is 433mbps on 5ghz and 300mbps on 2.4ghz.
Of which neither is going to hit those speeds. both because of wireless network overhead as well as distance/obstructions/interference on wireless.
What actual speeds do you get hardwired in?
And what router are you connecting it to?
