ov10mech
Apr 17, 2021Star
EX6100v2 No Gigabit Ethernet
This unit advertsies is has a Fast 1GB ethernet physical port. I have tried to connect it to several 1GB clients and even forced 1gb/full through the NIC settings. I am using a new CAT5e cable tes...
- Apr 21, 2021
I got this Fixed. Although Cat 5e cabled are supposed to run at 1gb for some reason this adapter doesnt like them. The cables I have work fine on other switches. I ordered a Cat 6 cable and it went in at 1GB first time. Case closed. Now getting 250mbps vs 100mbps on the bandwith.
ov10mech
Apr 19, 2021Star
Yes I understand about being limited to the WIFI. The ETH interface is only connecting in at 100mbps . Se I am being limited to 100mbps and I have a 250mbps internet connection
Apr 19, 2021Guru - Experienced User
the interface on what is showing that?
Did you ensure you're using cat 5e or better cables?
Have you tried different devices?
- ov10mechApr 19, 2021Star
Yes tried diff devices. All work fine with 1GB except this Netgear device. As mentioned in the original post cat 5e. Interface on a laptop or one of my servers in the link speed.
- plemansApr 19, 2021Guru - Experienced User
so you're connecting your laptop to it?
And you tried a different computer?
Have you looked at the ethernet connector on the extender to see if its got a bent/corroded pin?
