ov10mech
Apr 17, 2021Star
EX6100v2 No Gigabit Ethernet
This unit advertsies is has a Fast 1GB ethernet physical port. I have tried to connect it to several 1GB clients and even forced 1gb/full through the NIC settings. I am using a new CAT5e cable tes...
- Apr 21, 2021
I got this Fixed. Although Cat 5e cabled are supposed to run at 1gb for some reason this adapter doesnt like them. The cables I have work fine on other switches. I ordered a Cat 6 cable and it went in at 1GB first time. Case closed. Now getting 250mbps vs 100mbps on the bandwith.
ov10mech
Apr 21, 2021Star
Apr 21, 2021Guru - Experienced User
Glad you got it fixed!
