D-Lary
May 31, 2018Follower
EX6100V2 Range Extender - Channel numbers and 3 extenders in use.
I have 3 AC750 Netgear range extenders setup in my home. Should they all be on the same channels or different ones.
Example: 2GHZ band is on channel 01 and 5GHZ band is on channel 40 on all 3 range extenders.
Should each extender have a different 2 channel set?
1 Reply
- DarrenMSr. NETGEAR Moderator
The extenders will follow the same channel that the router is on so they would be the same.
DarrenM
