evpq
Jul 30, 2022Follower
EX6100v2 Unable to connect to the extender's network
GreetingsI I have a Netgear extender model EX6100v2 that had been working fine until a recent power outage in my neighborhood. Since that time the extender no longer works. I've tried the factory ...
Aug 01, 2022Guru - Experienced User
That device has an ethernet port on it.
Can you hardwire in a pc/laptop to it and attempt setup that route? (just make sure to disable wifi on the pc/laptop you use so it doesn't default back to that connection)
