afmarsh
Sep 18, 2020Guide
EX6100v2 will not connect to router
After reading back in this forum I see a lot of people having the same issue as I am for quite some time, with no resolution (I did reply to one from the other day). My EX6100v2 has been workin...
- Sep 19, 2020
I managed to solve my issue. I was also experiencing connectivity issues with select other devices which were all previously on the netowrk without issue. I ran across this in the Fios community and it worked. After making these changes, all devices including my EX6100v2 connected almost immediately after the updates went through. Appoligies for not giving credit to the user who posted the solution in the Fios community.
"...see if disabling SON helps by logging into router at myfiosgateway.com and go to Wireless Settings/Advanced Security Settings/ Other Advanced Wireless Options/Self-Organizing Network Enabled and set to Off"
jasonmc100
Sep 19, 2020Initiate
I'm having the same issues...just researching the boards but have done all the same troubleshooting. Just stopped working on 9/14 or 9/15. Also using Fios gateway with the EX6100v2.
afmarsh
Sep 19, 2020Guide
hmmmm that's when mine went down too. Weird.
I'll know soon if mine was defective, they're replacing it since it's under a year old. Will update here.
