mrosen
Feb 19, 2020Tutor
EX6100v2 Won't let me register
I have been having problems trying to reconnect my extender using WPS so I'm trying to use mywifiext.
I connected to the extender with my phone and got the registration screen.
I've completed every field but the "next" button is still greyed out.
Thanks.
- mrosenTutor
I managed to get in by using a completely unsecure password. Kind of defeats the purpose of a password manager if you won't accept its passwords.
Now I have been prompted to change my password (of course) and it won't let me re-enter the password. The box is greyed out.
Try the setup without using the wps setup. theres the smart connect wizard.
Factory reset the extender, re-setup the security on your router, then go through the installation wizard. the 2nd video on the support site shows it.
