jking5296256's avatar
jking5296256
Follower
Nov 08, 2019
EX6110-100NAS WI-FI RANGE EXTENDER
I'M HAVING TROUBLE CONNECTING WITH THE NETGEAR INSTALLATION ASSISTANT
1 Reply
  • plemans's avatar
    1. Plus hit the caps lock botton. its to the left of the "a" key
    2. What trouble are you having? Details help the most. Just saying it doesn't connect doesn't tell me where in the process its failing. Are you having issues connecting to the wifi? Problems going through setup? Problems connect it back to the router? What all is going on?
    3. Are you trying the wps method or the manual connection method?
    4. what firmware are you on?
    5. Router you're connecting to?
    here's your support page it has the manual with more detailed install instructions, an install guide, troubleshooting, and firmware. Its a great help when you're stuck. It even has install videos.
    https://www.netgear.com/support/product/EX6110.aspx
