jerryrice420's avatar
Aug 23, 2020
EX6110 Configuration
I am having issues getting my EX6110 to work correctly.  Here is my overall setup: 1. WNR3500Lv2 as edge device, wireless disabled 2. Nighthawk X6 R8000 in WAP mode, with SmartConnect enabled 3. E...
  • plemans's avatar
    Aug 24, 2020
    Your problem comes down to only wanting 1 ssid. none of your devices are "mesh" devices.
    Meaning you can set them up with the same ssid but they'll be sticky. Meaning they won't roam like mesh devices.
    Options?
    1. get a mesh extender that you plan on running as a wireless extender. they work great with 1 extender. If you need more than that, look to option 2
    2. upgrade to a full mesh system like orbi that supports wired and wireless backhaul and using single ssid function.
    3. Have 2 ssids. Use the 2 R8000's (both outside of the closet) and run them with smart connect but have 2 different ssids. One for each side of the home. If possible have both hardwired in and run 1 in access point mode. Just make sure they use different wireless channels so they don't interfere with each other if you use this route.
