Souwester
Mar 07, 2022Tutor
EX6110 Setup
I've followed the set up instructions, lights come on etc, I can 'see' the SSID plus EXT (both 2G and 5G) but when I enter the password (same as for the router) it comes up with 'Incorrect password ....
Mar 07, 2022Guru - Experienced User
did you set it up using wps?
Sadly, to frequently wps gets coded different between manufacturer's (it shouldn't).
In those cased, try factory resetting the extender and installing it using the installation assistant instead.
- SouwesterMar 07, 2022Tutor
Thanks for reply, but that's not working either - i can't get mywifiext page to load, have tried the 192.168.1.3 approach also, just not happening.
- plemansMar 07, 2022Guru - Experienced User
the "192.168.1.3" approach?
I mean push and hold reset for 7-15 seconds while its powered on.
Then follow the installation assistant. heres a video.
https://www.youtube.com/watch?v=yJVklshxBMk
I did another reset, and this time managed to connect through the Netgear_ext. The wizard appeared, so I have been able to get the EX6110 running now. Don't know why it wouldn't do it for several previous attempts, but OL now. Thanks for your help.
