Souwester
Mar 07, 2022Tutor
EX6110 Setup
I've followed the set up instructions, lights come on etc, I can 'see' the SSID plus EXT (both 2G and 5G) but when I enter the password (same as for the router) it comes up with 'Incorrect password ....
Souwester
Mar 07, 2022Tutor
Thanks for reply, but that's not working either - i can't get mywifiext page to load, have tried the 192.168.1.3 approach also, just not happening.
Mar 07, 2022Guru - Experienced User
the "192.168.1.3" approach?
I mean push and hold reset for 7-15 seconds while its powered on.
Then follow the installation assistant. heres a video.
https://www.youtube.com/watch?v=yJVklshxBMk
- SouwesterMar 07, 2022Tutor
I did another reset, and this time managed to connect through the Netgear_ext. The wizard appeared, so I have been able to get the EX6110 running now. Don't know why it wouldn't do it for several previous attempts, but OL now. Thanks for your help.
- plemansMar 07, 2022Guru - Experienced User
Glad it worked!
If you mark it solved, it'll keep others from wasting time trying to fix an already fixed issue :)
