GrahamTate
Oct 12, 2020Follower
EX6110 won't produce extender network NETGEAR_EXT
Following instructions, using installation assistant, paragragh 1 states that upon plugging in the range extender near to the Hub two green LEDs will glow. That happens but the next step, opening WI...
- Oct 12, 2020
did you try factory resetting it?
Push and hold reset for 7-15 seconds while its powered on?
Oct 12, 2020Guru - Experienced User
