Vittoria2
May 08, 2026Aspirant
EX6120) - AC1200 Keeps dropping connection to pool controller 2.4g
I have used the EX6120) - AC1200 range extender since 2019 for use in my backyard pool area. For my own personal use I use the 5g band, but I have a pool controller about 40 feet from the house tha...
CrimpOn
May 08, 2026Guru - Experienced User
WiFi is really sensitive to material in the direct line of sight between units. Has anything changed since 2024 that might impact the radio link?
Vittoria2
May 09, 2026Aspirant
The extender hangs on a curtain rod facing outwards directly to my pool. There is nothing at all between it and the pool controller. Restarting fixes it, but it happens again at any random time. Nothing at all has changed in years out there. This just happened a few minutes ago, and at that time I connected my iPad to it and the 2.4 was working fine. I restarted it anyway, since the iAqualink unit had the red dot. After the restart it had a connection again.
