BatExige
Apr 15, 2019Tutor
EX6120 - the 2.4 ghz network working but I'm unable to connect to the 5ghz "DHCP lookup failed"
as the title says: EX6120 - the 2.4 ghz network is working but I"m unable to connect to the 5ghz network though the extender. Error message "DHCP lookup failed"
I've updated the firmware, chang...
- Apr 16, 2019
Is your router setup with any fancy routing/static routes/device?
If not, i'd just go full nuclear and do a full reset on both devices. Start back at factory with both of them. Do a reset of both and set them both up first before adding any other devices (other than the device you use to set them up). You could troubleshoot both devices all day and not figure it out. I doubt its the extender as you've replaced it once and gotten the same error.
I've hooked a netgear extender to a C6300 without issue so they should work.
BatExige
Apr 16, 2019Tutor
thank you for the response.
my router is a Netgear C6300-100NAS AC1750.
I have not done anything on the router end, other then changing the channel.
can you direct me to any procedures on how to perform DHCP setup troubshooting? this is out of realm of my knowledge. Thank you!
Apr 16, 2019Guru - Experienced User
- BatExigeApr 16, 2019Tutornope, I've left everything default other than changing wireless channels. I'll try the nuclear option and start both from factory settings. thanks!
welp... the nuclear option did the trick.. until it asked me to update the firmware. After firmware update, 5g is toast again. Gonna try again, sans firmware update this time. :smileytongue:
- plemansApr 16, 2019Guru - Experienced User
always good to do a reset after a firmware update anyway. Hopefully it works ok this time!
