greengiraffe_7
Mar 17, 2026Aspirant
EX6120 & AT&T Fiber Connection Issues
I'm similar connection issues as others with my EX6120 after I switched to an AT&T Fiber router. I follow all the instructions, it connects, I connect the various devices then after a certain amount ...
CrimpOn
Mar 17, 2026Guru - Experienced User
greengiraffe_7 wrote:after a certain amount of inactivity
Please explain what this means.
greengiraffe_7
Ok, I have my extender plugged in behind me in my office, so I've connected my HP that never leaves to it. The AT&T router is in the room next door about 15-18' away. After a period of time, if I put the computer to sleep or shut down, when I go back to start working on the laptop, the "device link LED" is not on, but the "router link LED" light is but my network doesn't show connected. Same thing happens when I try to connect my bedroom TV to the extender. I'm typing in my password every time, but network always recognizes the router and will connect.
- FURRYe38Apr 21, 2026Guru - Experienced User
Any progress on this?
