Plangham
Feb 21, 2019Follower
EX6120-100UKS can the antennas be removed
Hi can the antennas be removed to use yagi instead to further increase the range. EX6120-100UKS model
michaelkenward
Feb 22, 2019Guru - Experienced User
What are you trying to achieve?
The EX6120 is not exactly the most capable wifi extender on the block. Messing around with antennae designed for different RF frequencies probably won't gain much.
You might do better with something more capable.
