Nakatomi
May 28, 2021Aspirant
EX6120 5GHZ Won't Work
I have the EX6120 Wifi extender and for some reason it will no longer connect to the 5GHZ network I have set-up, I've just about 10 mins ago did a complete reset of the networks and I can still connect to the 2.4ghz but not the 5GHZ, it has the latest firmware as well. When trying to connect via my Samsuns S20 mobile I get "Couldn't get IP Address"
What router are you connecting it to?
Did you set it up using wps or the installation assistant?
- NakatomiAspirant
The router I own came from my ISP its a Technicolor DGA2231 and I set it up via my laptop via wifi like I first did when I first got it last year, everything sets up fine the extender sees my main routers 2.4/5ghz signals and I set them up with 2 different names make a password for them both and continue with set-up.
Everything is fine and it says its completed set-up the 2 new extended wifi signals are broadcasting because my hardware like phone laptop see them both, I can connect to the 2.4ghz band fine but 5ghz it just sits there and gives me couldn't get IP address. Yet I have it set up to handle them its self I also have on my main router the IP address for the ext to perm keep it for that item.
