Roselea0392
Jul 23, 2020Aspirant
EX6120 AC1200 DUAL BAND not accepting router password
Hi all, Hopefully I'm missing something obvious but it doesn't seem like it. I have installed the WiFi extender correctly and the ext2G and 5G networks appear on my device WiFi as options to con...
Jul 24, 2020Guru - Experienced User
What router are you connecting it to?
What firmware is on the extender?
Did you set it up via wps? if so, i'd highly recommend resetting the extender and re-setting it up using the installation wizard. Wps can get coded differently between manufacturers and this can cause issues.
cathun44
Jul 30, 2020Aspirant
Thank you, I was having the exact same problem and your solution worked.
FYI Once connected to the extender network NETGEAR_NET I could not connect to the website to set up the extender via Chrome I had to use Internet Explorer.
