NodJr
Mar 20, 2021Aspirant
EX6120 AC1200 isn't working properly
Afternoon all, Background I have had an engineer out several times to investigate the 'line' and ensure my internet is working. The line is now fine, bios reports are great and a new router fro...
Mar 20, 2021Guru - Experienced User
How big is your home?
what materials is your home made from (certain materials block wifi)?
How far from the router is the extender?
If you log into the extender, get a screen snip of the status page. It should show us connection strengths that can help.
Are you using fastlane mode?
- NodJrMar 22, 2021Aspirant
Home is medium size
Router in opposite room, less than 10 meters
Wall materials -plaster board, minimal effect, signal strength is strong
I have not started fastlane mode - Unsure if the Now Hub2 would support 5Ghz to allow 2Ghz fastlane for the extender
Images attached, all the details provided are strong, does not make sense why devices are not getting consistent internet
Please advise?
Many thanks,
Images didn't load PSB
many thanks.
